Antenna identification
KD9RTX
Does anybody have any documentation for the identification of Tait antennas? Specifically the TP93xx and TP81xx series. I have a couple of TP8120s in UHF 1 both with the 2.5" stubby antennas but one antenna has a green dot on the top end and the other has a brown dot. Both seem to work equally well but there must be some kind of difference for them to be marked differently.
KD9RTX
Surprised I didn't come across that document. I checked my 2 stubby UHF antennas and a couple other Tait antennas I have. No markings on the connector like you'd find on a Moto antenna. Just the colored dots on the end.
headsense
Australia
TP8100/TP9100 antenna 400–470MHz helical TPA-AN-013 H5 74mm ±6.5mm brown
TP8100/TP9100 antenna 400–470MHz whip TPA-AN-011 H5 160mm ±3mm brown
TP8100/TP9100 UHF antenna selection kit5 TPA-AN-016 H5 or H6 various n/a
TP8100/TP9100 antenna 450–520MHz helical TPA-AN-015 H6 67mm ±6.5mm green
TP8100/TP9100 antenna 450–520MHz whip TPA-AN-012 H6 135mm ±3mm green
TP8100/TP9100 antenna 762-870MHz 1/2 wave whip TPA-AN-022 K6 180mm n/a
TP8100 antenna 762–870MHz helical TPA-AN-028 K6 68mm ±6.5mm blue
TP8100/TP9100 antenna 896-941MHz 1/4 wave whip TPA-AN-024 L3 85 mm ±3mm white
TP8100/TP9100 antenna 896-941MHz 1/2 wave whip TPA-AN-025 L3 175mm n/a
TP8100 antenna 896–941MHz helical TPA-AN-029 L3 59mm ±6.5mm white
headsense
Australia
TP8100/TP9100 antenna 136–151MHz helical TPA-AN-002 low B1 183mm ±10mm black
TP8100/TP9100 antenna 150–162MHz helical TPA-AN-003 mid B1 170mm ±10mm black
TP8100/TP9100 antenna 162–174MHz helical TPA-AN-004 high B1 155 ±10mm black
TP8100/TP9100 VHF antenna selection kit3 TPA-AN-005 B1 various n/a
TP8100/TP9100 antenna 136-225MHz tunable4 TPA-AN-001 B1 or C0 186mm ±5mm black UHF
TP8100 antenna 350–400MHz helical TPA-AN-017 G2 88mm ±6.5mm yellow
TP8100 antenna 350–400MHz whip TPA-AN-018 G2 188mm ±3mm yellow
TP8100 antenna 340–390MHz helical TPA-AN-019 G2 custom 90mm ±6.5mm red
TP8100/TP9100 antenna 380–420MHz whip TPA-AN-010 H4 181mm ±3mm violet
TP8100/TP9100 antenna 380–420MHz helical TPA-AN-027 H4 79mm ±6.5mm violet
headsense
Australia
KD9RTX it sounds like your best sticking with Brown dot for R1 and Green dot for R2 band. Above is factory specification data TPA-AN-XXX is the required part numbers if your looking to purchase genuine.
