01-00 General heap error
Contact GRE Support and provide error code information
01-01 Unable to allocate from heap
02-00 Unknown object type in data
Use PC Application to delete any corrupted objects or create a new configuration
02-01 Unknown TSYS type in data
Use PC Application to delete any corrupted TSYS objects or create a new configuration
03-00 No MicroSD Card inserted
Ensure that a properly formatted MicroSD card is fully inserted and locked in the MicroSD slot.
03-01 General error initializing file system
Reinsert the MicroSD card to ensure it is fully inserted in locked in the MicroSD slot. If necessary, reformat the MicroSD card using the PC Application “Prepare SD Card for use” option. Replace the MicroSD card if the problem persists.
03-02 Cluster size bad Reinsert the MicroSD card to ensure it is fully inserted in locked in the MicroSD slot. If necessary, reformat the MicroSD card using the PC Application “Prepare SD Card for use” option. Replace the MicroSD card if the problem persists.
03-03 Error reading MicroSD card
03-04 Error writing MicroSD card
03-05 MicroSD Card is full
Reduce size of configuration, remove unnecessary audio recordings or switch to a MicroSD card with more capacity.
03-06 MicroSD Card is write protected
03-07 Mass storage mode is active
Under normal conditions this error should not appear. Mass storage device mode is disabled when the scanner is connected to a computer and scanning. Disconnect the radio from the computer, wait a few seconds, then reconnect. Contact GRE Support if the problem persists.
03-08 Unknown MicroSD card read/write error
04-00 Initialization error Contact GRE Support and provide error code information
04-01 Initialization error Contact GRE Support and provide error code information
04-02 Firmware load error
05-00 Unable to load CONFIG__.BIN
Reformat the MicroSD card using the PC Application “Prepare SD Card for use” option. Replace the MicroSD card if the problem persists.
05-01 CONFIG__.BIN file error
05-02 CONFIG__.BIN file error
05-03 CONFIG__.BIN file error
