Full size van... OK this actually makes this easier..... front hood lip mounted NMO near the driver's or passenger door area would be the best bet actually for your VHF, but if you must roof mount it, then do an longer cable run and NMO mount it iether center front, or center towards the rear. The magmount CB and scanner ants can be done in a row behind this as long as you leave a couple of feet between them all.. You can drill and add a ring to run the cables from the mag mounts in the roof, but youd be better off doing all around NMO... The best set up I have seen on a work van was middle center roof CB, right rear VHF, left rear scanner, and hood lip mounted 800/900 MHz. Magnet mounted CB and scanner ants do give the flexibility to place anywhere pretty much, and move around for best performance... Seriously look into NMO hood lip mounting that VHF. It helps eliminate too much clutter rooftop. On average your antennas will add around 30-40 inches of hieght overhead. Average VHF is as follows- iether 3 inch coil base, and 32 inch whip, or an non coiled 12 inch whip. CB mag mount is usually 2 to 4 inch coil base depending on if its a high gain supertuned, or standard, and about 40 inch whip. Scanner mag mounts vary depending on type.. but the Hustler MRM, and RS models if not modded, have an 3ish inch base assembly with total whip of 32 inches. The RS can be modded to an single coiled 16/17 incher.
