billybobears
Hello fellow listeners:
I just mounted a Bearcat antenna on a 3/4 " 10 foot high piece of galvinized conduit along side of my house - putting the antenna about 5-6 feet above roof line....I don't "do" roofs so I couldn't get any higher or believe me, I would have....I live in a valley in Northern New Jersey (Wanaque (very little reception due to mountains all around us)) where we get maybe 6-8 vigorous thunderstorms a year with some nearby lightning strikes and my hosue is surrounded by trees that average 60-80 feet in height. We've never been "hit" by lgihting nor have the trees, so far as we know.
Question is this: I went to Home Depot and picked up an 8 foot copper ground rod, some # 4 open copper strand wire, and a a few clamps. Help at Home Depot told me to drive the copper rod (as much of the eight feet) into the ground for good protection. If cannot do so due to rocks (and we have a lot of 'em) - go as deep possible, cut the excess above ground and drive in a second rod and clamp that to the first rod, using the same # 4 wire.
So now I will have a "ground field" of sorts, (I guess).....
First: will this work to protect the house in case the antenna takes a lighting hit, either direct or "fragmented" from a hit to a nearby treee?
Second, do I need additional ground or surge protection at the point of entry to the house and for the coax cable as well?
I'm not protecting anything too valuable in the way of my scanner - it's a Bearcat BC898T - but I'm attempting to protect everything in my life (and my wife) with the house and all the other electronic goodies we have, lights, refrigerator, microwave and stove not counted.
I got into this because we never had a big ole' stick of metal sticking up into the air above our humble abode before and prior to next spring when that occassional thunder-blaster rolls through, I want to be ready for the worst possible scenario.....
Any help - much appreciated - as usual - I find that there's a lot of wisdom out here and you're all mightly generous in sharing same.....
Thanks folks!
Happy listening.....
Bill
Thanks folks!
Bill
