BCD436HP/BCD536HP: 1 FREQ DMR (Same Color), Same Dispatch ... AGAIN
Heidi750
Kimberley, BC
OK just when I thought I had it figured out ... NOT.
I have 5 Fire Departments (5 different TGIDs), working off Same Dispatch, Same Freq (163.545), Same Color Code (1), Same Slot # (1)
I had tried 1 System, 5 Departments ... but ended up with the same problem below.
I have now set up a system for each Department.
My problem seems to do with the UID #s ...
I have entered the UID for Dispatch (11,13,24) on each System.
Sometimes everything lines up and the display looks good, other times not so good.
** They also Dispatch Rigs from 2 different stations (Car 1099) ... so they are Dispatching to 2 different TGIDs at the same time?
Seems like when it's scanning it stops and displays the 1st system that is displayed for the Dispatch UID#.
It displays 1 of the 5 Departments while displaying parts of the Department Dispatched.
Question: If I delete the Dispatch UID from each Department will that omit all the communication from Dispatch.
Is there a way to correct this???
(it's probably an easy cure ... but I'm just not seeing it)
Waiting to Hear from You ...
436isthe1
Whistler ws1080/Uniden 436hp/GD-77and Cobra 29 ltd
Missouri
My counties Sheriffs Dept and Fire Dept have same issue, I could copy the channels from Sentenial because my Sheriffs dept name would come on my display screen while the fire dept was transmitting . I had to to the 1 dmr channel thing.
Ubbe
Stockholm, Sweden
No, there's no way to filter based on UID, only TG's.
Can't you just put all TG's and UID's in one system and in one and the same department?
/Ubbe
