137.9375 Mhz unknown
PDXh0b0
Woodland, WA
I hear this mostly on weekends(because I'm sitting around)
Set up is a qfh antenna /srd recording noaa & meteor weather satellite transmissions....
Location Woodland Wa
Sounds something like in-flight testing
Audio recording am modulation
TerryPavlick
Wallingford PA Villas NJ
Sounds more like an aerobatic team practicing - they are way out of band using that frequency.
Just curious - could they be on a regular VHF airband frequency but overloading the SDR ? I have a similar issue here when monitoring my local airport unicom on 122.700 - the aircraft because they are very close by come in on 245.400 Mhz (but they are on 122.700)
BruceMichaels
Not "Some People"
Flying Over You
I've had the same thing on my RTL-SDR, but I just put it off as the SDR is a little warm. I haven't heard of the US using anything other than .025 steps.
PDXh0b0
Woodland, WA
Didn't see it with an rsp1a & jpole at 8mhz sample rate. Will make a dx mission out of this next Saturday 😀
AirScan
I agree with Terry, to me it sounds like some sort of aerobatic/formation practice with piston type aircraft. Maybe warbird types ? Can you provide a date and approximate time you heard that recording ? We might be able to ID the aircraft by checking the ADS-B replay. My first guess would be they are using a frequency between 122.000 and 123.975 MHz ?
PDXh0b0
Woodland, WA
04/19
14:10 - 14:33 PDT
TerryPavlick
04/19
14:10 - 14:33 PDT
Here is a guess but the logic of the aircraft's history makes sense
and this incident report involving the same aircraft
note this portion of the report....
Analysis
The group of 6 airplanes were practicing formation flight for an airshow the following day. The airplanes were to takeoff in three groups of 2-airplane elements.
picture of N526KP taxing by another aircraft that is not doing so well
PDXh0b0
Woodland, WA
Analysis
Makes sense, I have several hits from that plane. When it flies over there are usually 3 of them doing maneuvers
AirScan
The website is a bit dated but maybe it's these guys ? The West Coast Ravens.
I suspect they would be using an air-air frequency in the 122.000 to 123.975 range. If anyone in the area can confirm ?
