160 Mhz Base Antenna Recommends
My first external base antenna was a J-pole. Back when I first got my ham ticket, one of the local ham clubs would produce them en-mass and sell them at the local hamster meetup for around $35 back in the late 1980's/early 1990's, if I recall correctly.
Aluminum parts and pretty well built. I was happy with it since all I had at the time was a hand held radio and that didn't work well inside the house.
So, anything outside, even connected with cheap coax, worked much better than the stock rubber duckie on top of the radio. In my very limited experience at the time, the J-pole was the greatest thing ever since it really opened up the capability of that little radio.
As time went on, I moved up to a 50 watt mobile in the house and got a better antenna, better coax, increased height. Realized that while the J-pole worked well, it wasn't all that great an antenna.
When looking at reviews on the internet, you have got to consider what the reviewer is actually comparing the antenna to. Most of the ham reviews I see look a lot like this is the only external antenna they have ever owned and their glowing reviews are only compared to a rubber duckie on top of a $15 CCR from inside their basement.
robertwbob
KE0WRU
Northeast jasper county,missouri
A J-pole is a 1/2 wave end fed radiator with a 1/4 wavelength matching line. The matching line is trimmed to match the 2,500+ ohm impedance of the end fed 1/2 wave radiator to a 50 ohm feedline. The matching line should not radiate as it is a transmission line for its full length leaving the 1/2 wave section as the main radiator. There are problems with this antenna like common mode current on the feedline and having the feedline or metal mast unbalance everything. But its a popular antenna for some unknown reason and people use them despite the problems.
i know guys that swear by j poles. and we are on same thig,they cant hear what i can
N9DCW
Springville, UTAH 84663
What do you think about the aluminum open stub J-poles made by ARROW? Are they any better at all than other types of J-poles?
Material wise, it's probably pretty well built. I remember looking at some of their very early models and they seemed like they were put together well.
Performance wise, it's going to work similar to all the other J-poles.
So, paying more for durability, but specs will be similar.
robertwbob
KE0WRU
id pay more buy better than Jpole.very little more money and range increases greatly
N9DCW
CHEERS mate! Thank you. I really enjoy reading your sound experience and radio knowledge when I read other posts‼️I’m also WRMB766 Provo UTAH originally Auckland NZ🇳🇿
FKimble
Newnan, GA
Ref the Diamond x50, it is also made in a x50C model. Tuned to commercial frequencies, 148-155 MHz 450-465 MHz. My attic mounted x50A amazes me on its abilities.
Frank
