163.7000
riverradio68
Listening to Monday morning fed activity and the scanner (TRX2) keeps grabbing and holding 163.70000 NAC: 031 TGID: 65535 with no RID's but also no encryption, my scanner is set to hear the annoying sound rather than ignore it. 3 bars from NE Texas. NO voice activity, just hang on (Like dead key) for a few minutes then release. Wiki says it's ICE National Tactical, wondering if it might be used as a repeater input, any ideas?
dave3825
Suffolk County NY
What is see in nationwide freqs has a different nac
163.700 M169 NACICE NatTac 1National Tactical 1P25Federal
Wiki lists that freq both with and without a nac but the listed nac is 169.
Channel Overview[edit]​
162.825
162.925
163.625 Nationwide primary channel
163.650
163.675
163.700
163.725
163.775
170.675 Tactical
P25 Channel Overview[edit]​
163.1125 S - NAC Tac 3 (N169)
163.7000 S - NAC Tac 1 (N169)
163.7250 S - NAT ICE Direct (N169)
164.7875 S - NAT Tac 4 (N169)
168.5875 S - NAT Tac 2 (N169)
171.2500 R / 162.9125 - NAT ICE Repeater (N069)
  • Note: ICE uses common NAC 169 and 069 on many of the Nationwide channels**
riverradio68
Must be a shared channel and someone else is using 031 NAC. Something to watch I guess. Thanks.
NAC 031 has been reported as TSA and Federal Bureau of Prisons (including Seagoville), however CBP in Dallas has been reported on that frequency/NAC as well. Also it would be unusual to see the use of TG 65535 since that is a wildcard TG. One possibility why you aren't hearing voice is it could be part of a voter system.
ecps92
Taxachusetts
163.7000 $031 is ICE for their Dallas Repeater
in addition you may find the freq in use with $169 which is NAT Tac 1 or even $167 for a totally different agency over in Houston
based on the TG, someone is dead keying from Dispatch or a console
ecps92
Taxachusetts
NAC alone does not determine who the users are :)
riverradio68
Raleigh, ecps, Thanks for the info! Will keep an eye on this one.
ecps92
Taxachusetts
As an FYI, the above-described behavior sounds like the radio may be hanging up on a control channel. I've seen the exact same thing numerous times.
Good thought, but unless they have moved to a TRS, this is/was (with that NAC) a stand along Repeater
riverradio68
I cannot rule this option out. I am hearing a lot of possible CC activity in North Texas on Federal VHF and UHF. I'm almost certain the Bonham TX VA Hospital is on the Federal Motorola system the Dallas VA is using I just have not had the time to do some serious searching to properly identify whether this is true or not. MOST of the time Dallas Federal does not come in very well where I live (Up on the Red River) So when I do actually get around to it, I'll have to pull a few all-nighters and hope for good band conditions.
