Delivers1234
Hi. Looking for electrical help here.
So I have a Mr. BOSS that is charged 2.6A/HR Sealed Lead Acid Internal Battery. The charger is 15V 5A AC/DC Charger.
I would like recharge the batter without an AC connection. So if I hook up a 12 volt wire to the DC input is that enough to charge the batttery? Or should I take out the battery and charge it seperatly? Could I add two wires -,+ to the battery and hook it up to battery source?
Without a 120v outlet, how do i charge the battery? I have a 12 volt jumper for cars that has a cigarette output (12v). Is there a solar alterative? Or should I just buy a 2nd battery to use?
I took a picture of the battery. Its in the bottom so to change it i would have to tip the Mr. Boss.
Should I get a propane generator or simply a battery charger? This is for camping?
Please help.
I don't know how to charge the 2.6A battery, ie rate etc.
The XCW20 has a DC Charger (but I'm not sure what amps it gives from the DC. The company said it would not work.
Please help.
BOSS-XCW20 Battery Operated Shower System
The BaseCamp B.O.S.S XCW20 is the most advanced, portable hot water generator in the world. All you need is a charged battery, water, and a 1lb. propane cylinder to have hot water at your fingertips in even the most remote places.
www.mrheater.com
