I'm using DSD+ Fastlane version 2.368 and a two-dongle (Airspy) monitoring setup to monitor some local trunked systems. Here is the .BAT file that I am using:
start FMPA -i1 -o20003 -rc -f460.550 -_1 -wsl15.43
start DSDPlus -i20003 -rc -O NUL
start FMPA -i2 -rv -o20002
start DSDPlus -rv -i20002 -O NUL
This .BAT file successfully works on P25 systems, as well as a DMR Connect Plus system, and a NXDN 4800 baud trunked system. However, this BAT file will not work properly on a Motorola DMR Tier III trunked system. In order to get this .BAT file to work on the Tier III trunked system, I have to go into the DSD+ Control Channel Event Window under the "Control" tab and change the role from "CC Monitor (1 of 2)" to "Combined CC / VC Monitor". I then have to change the "Output" to "Synthesize all digital voice" . After doing this, it then works on the Tier III system, but only using one dongle instead of two.
Is there something about Motorola Tier III systems that would cause this, or is there something amiss in my .BAT file?
All of these systems are located in Broward County, FL.
