2 feeds 1 computer
ff026
ff026
here is my problem i have 1 computer and want to run 2 feeds at once.
Windows XP will only let me select 1 input at once.
i want to use the line for feed 1 and mic input for feed 2.
anyone know a way to do this?
i have a second sound card that i can install, if need be.
any suggestions appreciated!
Deziel0495
From my understanding, you would need to submit 2 feed requests. Once Accepted, you would then download the program (broadcaster) twice. Once for each feed. Then select which input you will be using for that feed. You would have 2 broadcasters running at once providing audio for each feed. I presume thats how it works.
ff026
ff026
i have been accepted for both feeds 1 is running now...
the problem seems to be that windows will not let me select more than 1 input for the 2 feed. i can only select mic input or line in not both.
Deziel0495
Oh, I gotcha now. I guess you might have to use that 2nd sound card. There is no way to select multiple inputs for Windows XP that i'm aware of.
Astrak
Mesa, AZ
You can't run 2 feeds on one sound card, the mic input and line in both go to the same place. The mic input is amplified before going to the computer.
ff026
ff026
ok so i will try the second sound card option then.
can i run 2 sounds cards at once and then tell oddcast which sound card goes to each feed?
ff026
ff026
got it working in about 5 minutes up and running now!
thanks all
GTR8000
NY/NJ Database Guy
BEE00
Splitting the line-in input with a stereo Y cable, you should be able to connect one scanner to the L channel, and the other scanner to the R channel. Of course, this method will only work if the broadcasting software/plugin allows you the option to select/pan either R or L channel for the source input.
I run a Dual Stereo feed. M-AUDIO make a sound card, (GordonE uses one,) that has 4 Mic inputs for a total of 8 Scanner feeds from ONE Windows XP Computer. of course the M-AUDIO card comes with a High Price, 1 to 3 hundred dollars. the next one for me is also by M-AUDIO but has two Mic inputs so I can run either a single Stereo feed or Split stereo and 4 feeds.
The currant software used on these feeds supports Stereo.
