2016 Cal-IFOG Released
kma371
The final version of the 2016 California Interoperability Field Operations Guide (CAL-IFOG) was released on 12/28/2016. It has a lot of good info in it.
Here's a link if you are interested in downloading it in PDF format.
http://www.caloes.ca.gov/PublicSafetyCommunicationsSite/Documents/Cal-IFOG_28Dec2016_FINAL.PDF
And with that said...I've already found several errors. The P25 Cities Project frequencies have the Tx/Rx info swapped and some of the CLERS system information has callsigns listed incorrectly.
The state needs a proofreader.
ke6gcv
Somewhere, Northern CA
But... But... But... It says FINAL in the link! Ha! +1 on the need for a proofreader!
Thank you for the information!
ke6gcv
California Military Department
Think I've found another typo.
Should the California Military Department's (as listed in the Cal-IFOG) alphabetical county list be following the new channel naming convention? I'm asking because it shows CLEMARS and NALEMARS as being the channel names instead of CALAW and VLAW, respectively.
Also... Should the California Military Department be California National Guard instead?
ecps92
Taxachusetts
All Depends on who it was created for.
This occurs quite frequently within ICS documents. Where TX/RX get transposed
The Repeater itself is transmitting on 173.5500
kma371
Well there you go getting all technical. This is California, someone messed up ;)
silverspy
Portland,Oregon
Tehama County "LE" Net listed in document.
Hello there everyone. I was wondering if anyone knows anything about the 172.5125, as listed in the Tehama County section of the document. Definitely looks like a Federal frequency. USFS, BLM, NPS? If
anyone knows the details of this, could they please report. Or maybe if someone in the area hears anything on this frequency. Thanks.
kma371
Probably has something to do with Mendocino NF
