I think position 1 was for the HF antennas mounted on the trailer hitch, not on the bed rail.
That makes more sense, but less at the same time. Is the trailer hitch a big mounting location for HF? Everything I've ever read or seen was bed rail, because the hitch is a terrible place with no meat underneath it.
Anyways, a frustrating update. I did get back at the truck with the multi-meter and laptop. First, I checked voltage with the fuses pulled for the ignition sense bus. I got zero volts, this was good news. I then checked each lead to the RF decks. The UHF deck had some voltage (0.875v), while VHF had no voltage. I also updated firmware with no change.
Secondly, while Black Friday people watching, I couldn't get the mobile relay to work. After a few times activating it and having zero luck, I gave up and moved along. After testing with the multimeter, updating firmware and verifying the programming for the mobile relay harness, I think I'm down to a physical problem with the VHF deck, which is Deck 1. When turning the car on and listening closely, I think I hear the startup 1ms beep out of the unselected deck speaker, indicating the UHF deck (#2) probably booting up, but not the primary deck that controls power to the control head.
The VHF deck it the one that got water in it and fried the KRK15 and the BT/GPS board. I suspect that there is also unseen water damage, or physical damage to the DB25, and the ignition sense wire is in circle of damage. Next step is to pull the deck out and crack it open to inspect for this previously unknown damage, but that's going to have to wait a few weeks. I have been successful in disabling the shutdown timer by holding the power on button till it powers up, so that's the work around. I'm guessing I may have to send the VHF deck our for repair, which I'm sure won't be cheap.
