ecps92 - thank you for the correction - this is the kind of feedback that I appreciate. I've updated the data on my end to show that correct information. I also have 32.1000 MHz FM [150.0 Hz] and 49.7000 MHz FM [150.0 Hz] listed for that same user, I believe 32.100MHz FM has been logged recently by other DXers who post on here, I can't say the same about 49.7 MHz FM.
Locally I can confirm that the Virginia Air National Guard uses, or used, 49.7250 MHz FM [150.0 Hz] for air to air comms but they appear to have switched to 41.5250 MHz FM [150.0 Hz] for that (at least as a primary frequency).
Thank you for confirming use of 39.5000 MHz FM [131.8 Hz] by Lee County.
39.500 MHz is interesting in that part of Virginia it is used as a multi-purpose frequency and also for fire dispatch (or simulcasting)
39.5000 MHz FM [CSQ] - Virginia Department of Corrections (alternate/secondary to 39.1200 MHz FM [136.5 Hz])
39.5000 MHz FM [CSQ] - Virginia state government general use (alternate to 39.540 MHz - SIRS)
39.5000 MHz FM [ ] - Craig County Virginia Fire Dispatch (simulcast) KIV527 - various tones may be used, or may be CSQ
39.5000 MHz FM [ ] - Alleghany County Virginia Fire Dispatch (simulcast) WPRU554 / KIF431 - various tones may be used, or may be CSQ
39.5000 MHz FM [110.9 Hz] - Wise County Virginia Fire / Rescue Dispatch (simulcast) KYB947
39.5000 MHz FM [114.8 Hz] - Carroll County Virginia Fire Dispatch KBP608
39.5000 MHz FM [131.8 Hz] - Bland County Virginia Countywide Use KWT748
39.5000 MHz FM [131.8 Hz] - Lee County Virginia Countywide "A" WNJL806
Band has been pretty screwy the last three days. Weird traffic on 39.240. Hadn't heard Lee County, VA in a while. Craig Co, VA was loud today. Band was definitely better on the upper end of 30MHz than the lower end.
