2055 Power supply
mikie333
MO & IL
I have a Pro-2055, but I don't have a power supply for it. There isn't a radioshack too close to where I am, so...
Does anyone know the volt/amp converter and "tip" I need (ie. J K, etc) ?
Thanks!
Grog
West of Charlotte NC
Thanks!
Voltage would be 13.8, amp should be at least 300mah but I would double check (I have mine packed in a box so it might take a day to be sure). I would check the tip to see if is positive or negative as well if you are using an aftermarket power source.
That tip was disconnected well over a year ago, a search on here should say what it is as it's the same as the 2096. I think it was the "T" size.
edit to add...
Lots of good info in this thread, including a universal part number for the tip.
http://www.radioreference.com/forums/showthread.php?t=50635
TES said:
The problem is that Adaptaplug "T" - used by the 2096, 2055, and possibly others - has been discontinued.
pj61
Quincy,MA
Had the same problem with the 2096. The power supply of the psr400 works on the 2096,
maybe it will work for you .
