25-pin D-SUB Connector
tetto
I'm looking for info on the 25-pin connector on ICOM radios. I have a F5400D and I see the pins can be reassigned/programmed in the CPS, but it's unclear how to actually utilize the pins.
For example, if I assign pin X to be an input function for the dimmer, what do I actually apply to that pin to activate the function? +12 VDC? Ground?
I found this thread which seems to be on the exact same topic, but it's still unclear to me. I don't understand the coffee bean references which may be part of my lack of comprehension. Paging @jeatock if you're still around :)
jeepsandradios
East of the Mississippi
The coffee bean reference is the pad on the circuit board in the radio that needs a solder blob installed or removed. Each input varies on a high or low trigger. You really need the service manual for the radio. Programming only goes so far.
