2m/70cm mobile antenna issue.
CptJbud
Florida Panhandle
Purchased a Diamond MR77 to use mobile with HT, with HT battery power. Reviews have been great on this antenna. Mounted center of roof (Hyundai Kona). When vehicle is running, I get great reception - with or without gps/infotainment car goodies on.. When in motion, however, it sounds like the signal is clipping. There is extra noise along with what almost seems like some of the signal is squelching out rapidly.. Is this "picket fencing"? Anything I can do about it? Would some ferrite beads help on the coax? Was also thinking of grounding the radio case through counter poise to cig lighter ground..
Appreciate any suggestions :)
mrweather
The MR77 appears to be a 1/4 wave antenna which will be more prone to picket fencing. No ferrites or grounding will help with that.
What other noises are you hearing?
CptJbud
Florida Panhandle
I believe it's 1/4 on 2 meter and 1/2 on 70cm. Happens on both bands equally though.. No other noises. Actually very clean with decent distance (ems and sheriff repeaters 40+ miles away) - just dirty and clippy while in motion..
bill4long
Indianapolis
Get a Diamond 770 variant. You'll love it. Folds over, and is 1 x 1/2 for 2m and 2 x 5/8 for 70cm.
KC3ECJ
What terrain are you in? If you have mountains, stay with the 1/4 wave at 2 meters.
jwt873
Woodlands, Manitoba
I'm thinking perhaps something is loose as well.
I believe the whip for your antenna is painted black.. I'd make sure the set screw is making good contact with the whip. The set screw might not have penetrated the paint when it was tightened down, in which case the resistance combined with the waving of the antenna in the wind might be causing the problems. If the whip is painted (or anodized) black make sure the part that makes contact with the set screw is clean.
nd5y
Wichita Falls, TX
What kind of radio is it?
Some Chinese radios with the transceiver-on-a-chip design have poorly designed firmware settings that cause excessive picket fencing or geiger counter sounding noises when moving that doesn't occur in real radios.
CptJbud
Florida Panhandle
Geiger counter noises - that's what I'm hearing in the backgtound.. Baofeng 8hp
KevinC
32D2T/957.282
Super Moderator
I'm everywhere Focker!
I've searched the Forum and Google and nothing comes up.
Here's one, took a out 15 seconds to find it.
