KB2GOM
I use the 396T to monitor New York State Thruway UHF frequencies. A hiss appeared on the system yesterday and persisted while attempting to remedy it, I inadvertently pushed a key (I don't know which one), and the 396T will no longer scan that system.
I checked; it is NOT locked out, but a "C" appears next to the system name when I drill down in the menu to the system options. Pressing the code to activate the system -- DOT 8 7 -- does nothing.
Apparently I invoked a command that causes the C to appear and the 396T to ignore that system. I tried toggling the lock-out options under the system options, to no avail.]
Can someone help? The only other option seems to be a total system reset.
