TheDM
Hello all,
Before I post this question, please let me say I combed through the forums and while I learned a lot I didn't get an answer to my question. So let me throw it out here and see if any sages or tinkerer's have the exact answer.
I live in SE Jackson County. Out near south of James A Reed Wildlife.
I am using a 396xt scanner.
I have the following:
Radio Shack Model: 20-006 whip antnenna (is this the best portable for non specific ranges?)
Center-Loaded Telescoping Whip Antenna : Telescoping Antennas | RadioShack.com
as well as
RadioShack® Outdoor Scanner/Ham Discone Antenna Model: 20-043
RadioShack Outdoor Scanner/Ham Discone Antenna : Scanner Antennas | RadioShack.com
I am wanting to run a cable through an existing hole in the house (vent for dryer) out to an external garage some 30' distant from the house. (Call it 15' of cable from desk to external vent hole)
I then want to mount an Antenna on the garage on the hope that it will be able to pick up say Raytown, KCPD, etc.
I know from my prior questions that the loss for using RG8 is going to almost nullify the use of the antenna (correct?).
So, if this is true is there anything I can do for say under $100 that would make a viable antenna situation so that I can pick up the broadcasts listed.
Is there a better cable or is there an amp i could use?
Any input would be appreciated.
Alex
as well as
Alex
