Good evening, all! I recently purchased a used BCD-996XT from eBay, and it came with a 4-pin mini-USB programming cable. (It doesn't appear to be Uniden, and I'm almost positive it's not the USB-1 cable.) Since it came with the scanner, I presume the previous owner was using it.
Anyhoo, it doesn't seem to fit in the front plug very well. Additionally, I can't get my computer to "see" the scanner. I am using FreeScan, and a Prolific-based USB-to-serial adaptor that works with the other serial programming cables I have (Kenwood commercial radios, PRO-2096 scanner), and Windows XP on a laptop I've used to program the afore-mentioned radios/scanner.
I'm not sure if the cable pins are making full contact with the pins in the front port. Other than that, I'm out of ideas.
Troubleshooting I've done without success:
- Changed baud rates of COM1 port (port that the USB adaptor is using)
- Changed baud rates on the scanner and in FreeScan
- Used the "Autodetect" function for finding the COM port in FreeScan
Any other ideas? Am I supposed to put the scanner in "program" mode, or is it just suposed to work once I plug the cable in and try to read from it in FreeScan?
Thanks for any help!
-Will
-Will
