407 etr
abrams
abrams
i tried that but it wont program in my radio i have a uniden 250 d and a bct15
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
pathalogical said:
The usual freq that comes up is 915.0000 mhz.
If that's on a TAFL search, I respectfully suggest that's going to be a data signal of no use to scanner listeners. I found the same kind of frequency allocated to some new devices popping up at weigh scale stations on Alberta highways a couple years back. It turns out that these are systems that receive some kind of transponder info - presumably from various trucks that buy into some kind of program to work with the scale crews/highway inspection guys. From what I recall of the 407, there are similar transponders used by 'regular' users of the highway, aren't there?
abrams
abrams
i am talking about the trucks that patrol the hwy.there two way radios.
exkalibur
York, Ontario
They used to be on the UHF "Passport Pals" system that MRC, Fleetcom and a couple other companies ran. However, coverage was horrible for them. Who knows where they ended up - my guess would be either Telus iDEN or Harmony iDEN.
Saint
Fort Erie Ontario Canada
Patrols
What are etr trucks ,If your talking about the MTO Ministry of transportation Ontario , they are on the Bell fleetnet trunked system now,
Steve
mciupa
Canadian DB Admin
Moderator
I'm here a lot
excalibur is usually the best informed source .
So, you most likely won't find the Roadside Assistance guys from 407 ETR using any monitorable radios.
How about you tell us the freq.'s ABRAMS Towing uses ? :twisted:
motomeso
Ontario
Actually the Passport mobile coverage is still quite good right to the 404 and I am sure was rock solid when Fleetcom was on board with the Ballantrae site.
plaws
E Hawkesbury Twp, ON
That's the transponder frequency. Same used for most of the others, i.e. I-Pass on Illinois Tollways. Since the Illinois I-Pass is part of EZ-Pass, I assume those are all on 915 MHz as well.
When you figure out how to jam it the account isn't charged, please let us know.
polkaroo
Missed him again!
the only thing jamming the transponder signal will do is tell the billing system you don't have a transponder and bill you the video toll charge as well. the gate takes a picture of your plate whether you have a transponder or not. so it actually works against you.
slicerwizard
Toronto, Ontario
407 ETR employees have to perform maintenance on the equipment boxes located on the on/off ramps. Those 270 degree ramps are dug in to the dirt with the excess piled up on either side of the ramp. PassPort coverage has always been horrible in those "canyons", even with Ballantrae, Toronto, Brampton and Oshawa on line. One of the worst locations I encountered was the eastbound onramp at Neyagawa - it's a big hole.
I found problems even on the main roadway; with some valleys, you'd lose your current site and the roaming took too long to find another site. The ETR folks were unimpressed and ended up sticking with Telus.
pathalogical
Toronto, Canada
lol...I don't plan on jamming it ! I've never used the 407 since it opened (I ain't payin' t'drive on it), actually when it did open, it was free for two weeks and I did use it daily going to/from work because the on/off ramp was right behind us. It took me 5 min less driving time but 10 km longer (one way) in distance. I didn't want the quicker wear and tear on my tires on concrete and after the two week period I never drove on it again. I graduated high school in 1986 and there was a popular slogan back then "407 in '87".
motomeso
Ontario
Makes sense, figured just the road maintenance crews would have been using the systems with mobile radios.
What was the sync pulse times set to on the Fleetcom sites and the scan hang times in the Passport personalities?
pathalogical
Toronto, Canada
hmm...Check out Tow Biz on OLN. Next time they key up the mic you can use Close Call to get their freqs coming right through your tv speakers. After all...yer right in front of the tv !!! hahahahaha lol lol And the owners manual says you gotta be within a thousand feet...yeah right...
Jay911
That makes about as much sense as using your mobile phone to have someone at home unlock your car doors with the spare key fob. :D
I did watch Tow Biz once ... I thought they were using MiKE phones.
motomeso
Ontario
Alls it takes is a scanner capable of tracking an LTR systems routed through your computers sound card and run an program called Invert to listen to your company.
