417.2000mhz
FireRescueMedic11
Banned
West Haven, CT
usually i listen during 12pm-1pm lunch hour at work, but when i go home at night i dont get much of anything, i dont know if they operate at night?...
but the 2 times i heard encryption was about 3-4 days ago, 417.2000 / 415.2000 no PL P25
LPD7
well in Boston, Base is in the Clear and mobiles are almost always Encrypted, but i dont know abour NYC
RDCat
N.W.
denver
in the clear on my 2096
should i just have it se on FM?????setting to decode it.....thanks
Analogrules
If you don't have one of those "expensive P25" scanners, it's encrypted in NYC. I'm not even sure if those scanners can even pick up everything on 417.200
Sybex7254
Florida
Huh? See my earlier post..it's P25 digital but in the clear in NYC, not encrypted.
maalox
n y c
yes i have to agree. i am listenig to it on my bcd996t here in nyc. 172.900 p25 is also active.
Analogrules
What I meant was that it would SOUND encrypted and you will not be able to pick anything up if you don't own a P25 scanner, like myself.
RDCat
N.W.
anyone monitor in colorado
ive got it plugged into my =
96 anyone hear it in denver?or any wher
skipshark773
Stuck in traffic on I-25
FPS in Denver are on the Buckley AFB Trunked system. In the Northern CO area (Boulder/Fort Collins/Cheyenne, WY) they operate on 410.800 with a DPL of 125. Signal is pretty good from FTC but may not be that great in the Denver Metro area.
ronhl
Live Free or Die St.
Update: "FPS Channel Change?"
A couple days ago here I heard them say they were changing channels.
Since then I found them on 408.20 P25 NAC:201...... meanwhile here in the New England area Ive noticed that 417.20 has since gone silent. Also heard them refer them as Denver Center. Dont know the reason for the change or if its temporary or permanent.
ecps92
Taxachusetts
Seems a major move is a-foot.
Phili was down for a bit during the cut-overs, which might explain Denver covering.
This am, Boston was still on 417.2000, however NH folks reporting 408.2000 [add 9 Mhz for the input]
Time for folks all over to RESCAN for this change.
texasemt13
CenTex DBA
Hunter, TX
No change in San Antonio, still 410.800MHz $715 as of 8:30am.
I'm still in the process of confirming that their talkaround is 413.950MHz. Our wiki says it is P25, but I'm still hearing only analog.
ChrisP
Portland, OR
417.2 should now be the input to 408.2 MHz, since this change is to move to 9 MHz standard repeater offsets in the UHF federal band.
- Chris
