Colin9690
County 21
APE282018
It means the radio signal is digitally encoded, so that only a radio with the correct "key" can decode the digital data to hear the transmission.
There is no scanner able to receive encrypted transmissions, because it's illegal.
rdale
Lansing, MI
danstrainz said:
really?so its like a tac channel?
No. It means that the transmissions are encrypted and you can't hear them.
BoxAlarm187
Level 6 RR Member (Since 1998)
Old Dominion
Dispatch channels, tac channels, any channel can be encrypted. There are lots of types of encryption. No matter which one it used, you can program the frequency in, but you won't hear anything intelligible on it.
STiMULi
Tucson, Arizona
01010100 01101000 01101001 01110011 00100000 01110100 01100101 01111000 01110100 00100000 01101001 01110011 00100000 01100101 01101110 01100011 01101111 01100100 01100101 01100100 00100000 01110111 01101001 01110100 01101000 00100000 01100001 00100000 01100010 01101001 01101110 01100001 01110010 01111001 00100000 01100011 01101111 01101110 01110110 01100101 01110010 01110011 01101001 01101111 01101110 00101110 00100000 01001001 01100110 00100000 01110100 01101000 01100101 00100000 01110000 01110010 01101111 01100011 01100101 01110011 01110011 00100000 01110111 01100101 01110010 01100101 00100000 01100011 01101111 01101101 01110000 01101100 01101001 01100011 01100001 01110100 01100101 01100100 00100000 01100101 01101110 01101111 01110101 01100111 01101000 00100000 01100001 01101110 01100100 00100000 01110111 01100001 01110011 00100000 01100100 01101001 01100110 01100110 01101001 01100011 01110101 01101100 01110100 00100000 01100100 01100101 01100011 01101111 01100100 01100101 00100000 01101001 01110100 00100000 01110111 01101111 01110101 01101100 01100100 00100000 01100010 01100101 00100000 01100011 01101111 01101110 01110011 01101001 01100100 01100101 01110010 01100101 01100100 00100000 01100101 01101110 01100011 01110010 01111001 01110000 01110100 01101001 01101111 01101110 00101110
Use this to figure it out :)
BoxAlarm187
Old Dominion
Depends on the radio system. Unless you're within a mile or two, you can't hear the tac channels where I volunteer either. However, all 13 tac's at work are repeated.
