460 Mhz DMR Station Reception
WILSON43
Northern New Jersey
Hello to all...
There is a Moto DMR station I used to monitor which is somewhat local, but apparently using a radio system generating weak signals outside of the
operating area of the complex. They are in the 460 Mhz range.
When I had my discone antenna mounted topside on my house, I was able to monitor the system. I've had to move the antenna to a new location
where the elevated height of the Discone came down around 15 feet and as a result, I am no longer receiving the above system.
I am using good coax and it goes into a Stridsberg Mulitoupler. I am receiving all the other system and stations on my SDS 100 and 200 that I received prior to
moving the antenna.
Any thoughts? I am stuck with the new location of the Discone but maybe a Yagi? Any other suggestions are appreciated.
Thanks, Dan
Try connecting the discone direct to the radio and bypass the Strideberg.
But, I agree with Merlin, try a Yagi. A UHF yagi is pretty small and will give you quite a bit of gain.
WILSON43
Northern New Jersey
Any particular brand or model Yagi you would recommend?
Dan
Dan
Search e-Bay, there's often good ones for cheap on there.
Lots of good brands, look for the commercial LMR manufacturers over the Cheap Chinese Antennas.
