HAARP Research Campaign 27-31 January 2025 UTC
wdreeve
Anchorage, Alaska USA
Please see attached Notice of Transmission for the research campaign.
Notes:
** There is new online form for submitting reception reports as indicated in the notice;
** The notice includes a Supplemental document with general information that we hope will help you observe the HAARP transmissions;
** Also included with the notice is an AIRGlow Observer Guide. We have plenty of darkness at 62 deg. N latitude right now so there may be some experiments to produce visible manifestations of the ionosphere heating;
** It is possible there will be a rocket launch at Poker Flat that will be supported by HAARP as indicated in the notice.
Whit
  • HAARP-Jan25-TransmissionNotice-V4.pdf
RFI-EMI-GUY
You might want to crosspost on the SDR receiver forum(s) as there is special benefit to monitor with SDR!
wdreeve
Due to extremely hazardous winter road conditions along the highways leading to the HAARP facility, the January Research Campaign has been delayed 1 day.
Please see attached Addendum 1 to the original Notice of Transmission.
The transmission notices are now posted at: https://haarp.gi.alaska.edu/transmissions including those dating back to 2022.
Whit
  • HAARP-Jan25-TransmissionNotice-ADDENDUM-Final1.pdf
dlwtrunked
27 JAN Hearing here in Virginia somewhat weak ongoing possibly ~15 kHz fast sweeps shifting up or down in ~25 kHz steps occasionally.
Now centered on 3280 kHz approx . Likely HAARP. Just shifted to center on 3255 kHz approx. and now 3205 kHz approx. And now 3175 kHz.
Note: Frequencies are approximate as signal is too weak above noise at present to get an accurate measurement.
