650 to 600mhz
bailly2
oops meant to write 750 to 760 mhz.
does motorola make radios that operate in this frequency range? if so what is the name of it? thanks
cmjonesinc
isn't that in the cell band? off the top of my head the closest you will get with a moto is going to be a 764-776ish
riveter
MD
If I'm not wildly mistaken, that's in the commercial LTE range...
bailly2
thanks everyone. found one, its the (CDM1550 •LS)
AAM255HF4DP5-N
700MHz (746-794MHz) 16 Channel 1-25 Watt Mobile Radio
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
What are you looking to do in that band? I seem to recall that JerseyNet, the testbed for the FirstNet system, is in place in NJ, and is about the only thing in that frequency range. However it's an LTE system, and the radio you mention above is an analog and LTR trunking radio (LTR is not at all compatible with LTE). Plus, the radio you mention is a very old Motorola model that's not in production any more as far as I recall.
If you're looking to be on FirstNet, you need an LTE compatible radio. There's a small handful who make radios with that compatibility, among them Motorola and Harris, but I don't know of any others at present. JVCKenwood is in the stages of coming up with an LTE/P25 radio, but I don't know if it's out yet.
cmjonesinc
Did you see the band splits on the spec sheet? It may not work for you if you're needing in the 750 range. It has some odd splits , 746-747, 762-746, 776-777, 792-794. Just out of pure curiosity what are you trying to listen to or transmit on?
