7" Wireless Book OS...
DocDaddy
Hale, Missouri
Hello All... I am wanting to restore the original operating system to my Wireless Book. I have no disk or manual for the unit. It does have a "reset" button on the bottom, but I don't know the sequence to start the restore process. Any help will be appreciated. Here are the specs:
WINDOWS CE 6.0 (BUILD 3122)
PROCESSOR - WMT, ARM-WM8505
MEMMORY - 256 MB SDRAM
HARD DRIVE - 2 GB (FLASH DISK + SYSTEM DISK)
DISPLAY - 7 INCH 800 X 480 HIGH RESOLUTION TFT-LCD DIDGITAL SCREEN - TRUE COLOR IMAGE
BATTERY LIFE - 3 TO 7 HOURS - DEPENDING ON USAGE
POWER DEVICE - AC/DC INPUT - 110-240 VAC 50/60 Hz OUTPUT: DC9V 1.5A
SOUND CARD - AC97
KEYBOARD - 80 KEY STANDARD QWERTY
WEIGHT - 1.36LBS
LAN - 10/100 MB ETHERNET PORT
WIFI - BUILT IN WIRELESS 802.11 B/G
RESET BUTTON ON BOTTOM OF NETBOOK
3 X USB (2 ON SIDE - 1 ON BACK)
1 X RJ45 LAN JACK
1 X 3.5MM HEADPHONE JACK
1 X 3.5MM MICROPHONE JACK
1 X SD CARD SLOT (SIDE)
1 X POWER INPUT (BACK)
OCO
Central Michigan
Not knowing anything about these "no name brand" Wireless Books, I Googled 7" Wireless Book.. After reading some of the forum posts, all I can say is good luck... There may be some valid links, but it looks like a lot of these were marketed by wood stove/vinyl window/weight loss sales hit and run types...:roll:
N2SCV
Above ground
Hi,
I followed the video but the Sylvania site says there are no downloads. Can you clarify? Tnx.
