700MHz Frequency List
KB7MIB
Peoria, AZ.
Wirelessly posted (Mozilla/5.0 (X11; Linux i686; U; en-US) Gecko/20081217 Vision-Browser/8.1 301x200 LG VN530)
So I did some searching with no luck. Does anyone have a link to a list of the public safety narrowband 700MHz frequencies, that also show their proper useage, such as general use, interop, low power, itinerant, etc?
KB7MIB
Peoria, AZ.
I found a bunch of FCC pages talking about the frequencies, but no actual list, unless it was in one of the "406 Not Acceptable" error messages I found. (My phone won't do pdf's, or a lot of other things, so it has to be plain text.)
GTR8000
NY/NJ Database Guy
BEE00
See the attached spreadsheet I created a few years ago.
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
The best source is the National Interoperability Field Operations Guide.
National Interoperability Field Operations Guide | Homeland Security
If you try to follow the download links from that page, which is what comes up on a Google search, you'll get 404 errors. It appears the links have changed and DHS has not replaced them.
The actual downloads can be had at Public Safety Technical Assistance Tools Website
KB7MIB
Peoria, AZ.
My phone doesn't show any attachment. Or maybe it's the mobile forums that doesn't show it.
KB7MIB
Peoria, AZ.
nd5y said:
You can find the 700 MHz public safety spectrum information on CAPRAD.
I didn't see a frequency list? I followed a link to the FCC, then to the eCFR. From there I went to Part 90, then to 90.613, which has the 800MHz channel/frequency list. That's what I want for 700 MHz. The 700 MHz bandplan only lists channels, and what...
KB7MIB
Peoria, AZ.
channels are used for what. But no list of frequencies.
KB7MIB
Peoria, AZ.
The NIFOG is in pdf. My phone won't do pdf's. (3G multi-media phone, not a smart phone.) I need a text version, on a website to read via my phone. If/when I (re)acquire a real computer, I will try to download the NIFOG.
nd5y
Wichita Falls, TX
It isn't on the home page. You have to hunt for it.
Go to caprad.org
Click the yellow 700 MHz tab.
Click visitors click here
Click continue
Click a region on the map or select one from the dropdown list.
On the left side under Planning Information click Spectrum Summary
Click Show All Channels
Now you have the 700 MHz public safety band plan. It is broken up into 12 pages.
As far as I know only the 12.5 kHz channels are used.
KB7MIB
Peoria, AZ.
nd5y said:
That's what I was looking for, thank you. (Bing didn't show that as a search result. And access to the wiki here via my phone can only be done via a direct link that someone posts, and even then, has only taken me to RR's desktop front page many times...)
KB7MIB
Peoria, AZ.
Another question, wouldn't the low power channels be simplex? They show as paired frequencies. Or would these be conventional repeaters installed in a command van-type vehicle for use at an incident scene?
nd5y
Wichita Falls, TX
Here are the rules regarding the low power channels. It doesn't say they have to be simplex.
90.531(b)(3) Narrowband low power channels subject to regional planning. The following narrowband channels are designated for low power use for on-scene incident response purposes using mobiles and portables subject to Commission-approved regional planning committee regional plans. Transmitter power must not exceed 2 watts (ERP): Channels 1-8 paired with Channels 961-968, and Channels 949-958 paired with Channels 1909-1918.
90.531(b)(4) Narrowband low power itinerant channels. The following narrowband channels are designated for low power use for on-scene incident response purposes using mobiles and portables. These channels are licensed nationwide for itinerant operation. Transmitter power must not exceed 2 watts (ERP): Channels 9-12 paired with Channels 969-972 and Channels 959-960 paired with Channels 1919-1920.
nd5y
Wichita Falls, TX
