If you do not see you NAC, though I'm sure it is in there as 293 is a default, common, NAC, select Digital Code Search and it will search for your NAC.SDS-100...
Hello all, I have the 700Mhz Medevac frequencies programmed in but have never heard anything. In Sentinel, do I have to set the audio type to digital, and select a NAC? What is the NAC? I don't see 293 in the drop-down.
Thank you.
Mike
Air Methods Life Net 81 (Hagerstown) * | 159.705 | FM | DCS 503 |
ExpressCare 1 (Martin State Airport) * | 453.425 | FM | CTCSS/DCS Search |
MSP SYSCOM Helimed * | 47.66 | FM | CTCSS 100.0Hz |
MSP SYSCOM Medevac * | 44.74 | FM | CTCSS 110.9Hz |
STATCom Medevac (Martin State Airport) * | 159.48 | FM | CTCSS 103.5Hz |
Helicopter Air-to-Air * | 123.025 | AM | CTCSS/DCS Search |
OK, Also, which one is patched to FIRST?If you look at what I posted you will see the 700MHz channels are the same. These are really NIFOG 700 A-G frequencies.
Got them in.For helo medevac I would really only load the last two talkgroups Helimed 7648 and Syscom 7640.
