700MHz repeaters
IdleMonitor
What's the scoop on the detachment repeater frequency?
I'm hearing this now in Renfrew, however I don't hear it unless I'm really close to the detachment. The Beat repeaters in town, are both stronger than this one. The LMRN repeater is much much stronger than the FleetNet repeater. With the LMRN repeater, I can have the antenna off my portable in my basement close to downtown and I can still hear it, but not the Fleetnet Repeater. Nowhere near as strong.
773.04375RM103.5 PLOPP DetachmentOPP Detachments Repeater
mikewazowski
Forums Manager
Oot and Aboot
It's meant to cover the officers while they're in the detachment so most likely low power and an indoor antenna. I wouldn't expect it to cover much more than the detachment.
hunterca
SDS150
Ottawa
Does this mean unit to unit without using the tower?
gary123
Pretty much. Think of it as a single freq. repeater but instead of talking to a base station it's talking to the talkgroup the radio is tuned to. So if the officer is on the local detachment TG, then the repeater links the portable to that TG. A major point on the repeater is that it only handles one TG at a time. I have not heard of several TG in use simultaneously. IE Detachment and K9. I suspect the Actual DVRS is programmed to just one TG.
hunterca
SDS150
Ottawa
Thanks for the info. I was listening to Ottawa Airport Authority frequencies (DMR) when I saw this
Aviator747
Cornwall, ON
There was an ambulance & PRU outside of work today. I caught 772.056250MHz on Close Call. It was normal FleetNet traffic.
gary123
That should be DVRS 04 with a PL of 131.8. VA3ADP is correct when they switch over to full LMRN the frequency will go ENC digital.
gary123
This is the EMS DVRS list I have.
771.843750 VR01 NAC A30
771.868750 VR02 NAC A31
771.893750 VR03 NAC A32
772.056250 VR04 NAC A33
773.031250 VR05 NAC A34
How does it compare to your list?
IdleMonitor
Just going by the database here and following along in the threads. Other frequencies I have programmed were all listed as Northern Ontario. Your digital listing looks more complete however. Personally I have only heard analog VRs 2, 3 and 5.
Analog VRs
VR01 - 771.84375 PL 118.8
VR02 - 771.89375 PL 127.3
VR03 - 772.05625 PL 131.8
VR04 - 772.13125 PL 173.8
VR05 - 773.03125 PL 136.5
Digital VRs
VR02 - 771.89375 NAC A32
VR03 - 772.05625 NAC 0D7
VR03 - 772.05625 NAC B64
VR05 - 773.03125 NAC 86B
gary123
Good. It looks like our frequencies match. All we are off is by the name. FYI, I get a TG of 65536 on the ENC users. I suspect this is a default TG for the portables.
gary123
I verify the 771.74375 and NAC as OPP DVRS 01. TG 256 is a new one.
IdleMonitor
Can anyone confirm a BEAT Repeater in and around the Kanata area? I was travelling along the 417 this morning and saw and heard BEAT 04-A Repeater (LMRN) - 770.91875 PL 97.4 show up. I do see that the Ottawa OPP Detachment is located in Kanata. Which is not far from the 417 so.
