I don't personally own a BC796D, but recently wrote a custom table for a different radio.
I've tried looking up information in the manual for that model, but there is next to no information about entering a P25 in this model.
Some say the radio is incapable of doing P25, others say it's do-able. It appears the radio is not capable of downloading the table directly from the control channel, so a table is required.
From my notes, you might try some of these. You should enter the complete table if possible.
If not, I might need to know which site on WISCOM you're trying to monitor to figure out which lines of the table are essential.
The polarity and upper base frequencies may or may not be required.
Code:
[color=red]Experimental[/color] WISCOM Band Plan for Uniden Radios
Band Lower Upper
Plan Base Freq Base Freq Offset Pol Spacing
1 138.00000 174.00000 0 POS 12.50
2 150.81500 173.99750 4096 POS 7.50
3 154.65000 174.00000 8192 POS 7.50
4 162.00000 174.00000 12288 POS 12.50
5 851.00625 868.98750 28672 POS 6.25
This table is for WISCOM only. Nobody has posted a file with information about DaneCom, so I can't help with that.
For specifics on your radio model, you might look at the
Phila, PA thread, and contact someone there about specific settings.
