800 mhz moto trbo
JASII
Memory Capacity
I ran a digital only search last night on 800 Mhz. Since I can't select DMR only or P25 only, I get both. Lots of ARMER frequencies, of course. I would lock those out to focus on DMR activity. In short order, I received a lot of Delta Air Lines, Inc. frequencies. They are MOTO TRBO Connect Plus. They all were using Color Code 1. There are two others that I am trying to figure out, though. They are 854.4375 and 861.0875.
854.4375 is licensed to Spectrum Solutions Network along with 854.2875. Those two repeater outputs are licensed for the Twin Cities area, but I can't determine what it is used for. I did not hear 854.2875 in use yet.
861.0875 is licensed, along with 861.3125, to Janus Spectrum Group LLC. I didn't hear 861.3125 in use. It sort of sounds like those two frequencies are a part of the Delta Air Lines, Inc. system, but just aren't licensed for it.
For those with Unitrunker or other radio software, would you be able to tune this in and see what you get?
854.4375 CC 1
854.8125 CC 1 CON Delta Air Lines, Inc.
854.8625 CC 1 CON Delta Air Lines, Inc.
855.7875 CC 1 CON Delta Air Lines, Inc.
856.7875 CC 1 CON Delta Air Lines, Inc.
857.2875 CC 1 CON Delta Air Lines, Inc.
857.3125 CC 1 CON Delta Air Lines, Inc.
857.7875 CC 1 CON Delta Air Lines, Inc.
858.2875 CC 1 CON Delta Air Lines, Inc.
858.7875 CC 1 CON Delta Air Lines, Inc.
859.2875 CC 1 CON Delta Air Lines, Inc.
859.7875 CC 1 CON Delta Air Lines, Inc.
859.8375 CC 1 CON Delta Air Lines, Inc.
860.5375 CC 1 CON Delta Air Lines, Inc.
860.7875 CC 1 Delta Air Lines, Inc.
861.0875 CC 1
