800 MHz sweeper?
mancow
N.E. Kansas
Recently I've noticed what looks similar to the HF propagation sweepers but in the 800 MHz range. It starts at 831.600 and sweeps to 861.450 in 150 kHz steps every 17 seconds.
Any ideas what this could be from?
mancow
N.E. Kansas
Yea I wonder if it's a 900 MHz image or maybe something local in the house or nearby or there is some sort of diagnostic system at the local P25 system tower that is sweeping the antenna for resonance. At least that's what I can theorize.
RFI-EMI-GUY
Certainly does not sound like anything FCC compliant. When you track it down, let us know.
You might check to see if their is a fundamental at 1/3 or 1/9 etc ., of the frequency. It could be a harmonic from some other service.
Sent from my SM-T350 using Tapatalk
RFI-EMI-GUY
Do you have another scanner running neaby?
Ubbe
Stockholm, Sweden
It couldn't be any of your own receivers searching that range and you pick up its local oscillator?
/Ubbe
mancow
N.E. Kansas
I do. Now it is gone. I wonder if propagation was bringing it in. I will try to set up the same scanners and watch for it again tonight to see if it can be duplicated.
zz0468
Banned
If you see it again, try changing the RF bandwidth of the SDR and see if it goes away with either a wider or narrower RF span. Frequently, when I see anomalies, changing the span I'm watching makes them go away. I'm not sure what the mechanism is, but it might be some sort of aliasing occurring in the A/D sampling.
majoco
Stirrer
New Zealand
What receiver are you using? If it's something with a wide open front end, ie. no filters, it could be a sweeper in a completely different frequency band.
RFI-EMI-GUY
Maybe one of your neighbors bought one of these to mess with you:
RFSG002 -- 45 - 2700 MHz RF Signal Generator On Sale! - HCF Engineering
http://www.hcfengineering.com/RFSG002_PS_REVD.pdf?attredirects=0&d=1
I bought one a few years back for a project and it has a pretty cool frequency sweeper. I just swept the FRS/GMRS band the other day and honestly, this could be used as a jammer with a proper amplifier connected. I bought it as a portable generator to test repeater desense in the field so I wouldn't need to lug my 8920B onto planes. The only complaint is that the 1000 Hz tone isn't quite 1000 Hz so my Motorola portable SINAD meter said "meh?" when connected.
mancow
N.E. Kansas
Airspy 2 on a DPD Productions LOG periodic at about 25 ft.
mancow
N.E. Kansas
Ah geez, it's the PRO-197 searching lowband from 35-50 MHz. I disregarded it because the 197 didn't have an antenna attached at the time.
Don't I feel stupid.
