Anytone 878UVII plus CPS writes wrong frequency to radio
KD1JAK
My 878UVII plus is not correctly programming the frequency from the CPS to the radio for my digital hotspot channels. Hotspot frequency is 438.46000. That's what I set in the CPS. When I write to the radio all those digital hotspot channels read as 142.11250 on the radio. The radio and CPS are both 3.08. The radio is in "Maintenance Mode", 00014. I haven't used the hotspot for months, so I don't know when this started. I am a novice, so I don't know where to start. Any help would be much appreciated.
Alarms50
Ossining, NY
Verify that you are reading the radio first. Once that is done, then you can edit the program file. If the radio mode (i.e. mode 14) does not match the CPS mode, the CPS will not allow you to program ady frequencies that the mode allows.
KD1JAK
@KD1JAK If you have updated the firmware recently, have you reset the radio afterwards, as recommended by Anytone? Radios that have not been reset after a firmware update have been known to do weird things.
Yes, I updated to 3.08 about a month ago. I "thought" I reset the radio afterwards. I reset it it yesterday and re-wrote the code plug from 3.08 CPS. Is there some way I can rule out this as a source of the problem?
chief21
Western NC (Summer); Tampa Bay FL (Winter)
Are you still having the original problem after the reset? If so, I suppose that the "failure to reset" was not the cause of the problem.
