XTS3000 Motorola xts 3000 codeplug too new for CPS
Video1
I Just bought a Motorola xts 3000 with Saber/3000 CPS. When I read the radio it comes up with the error "codeplug Too new for this application" along with two other errors "Unable to unpack block external radio BLK" and, "Pass2-Unable to transfer Block external radio blk From CpDp to Dd unpack Failed". I am currently running Saber/3000 CPS 4.0.1.02. Has Anyone ran into this? If not is there a way to create a code plug in the CPS and write it to the radio.
nokones
Sun City West, AZ
I have the 5.03 CPS.
Are you using a XP 32-bit Windows Operating System? Are you using a RIB connected to a real Serial Port or are you trying to use an USB to Serial Adapter with the RIB?
If you are unsuccessful in finding someone with the latest CPS version, you can send me your portable and I can program it for you or you can send me your programming information and I can build a codeplug and send it to you and you can try to see if that will work. Of course, it depends on the model XTS3000 your have.
What model do you have?
Video1
I was able to find a 5.0 Cps disc. it works with the radio. thank you for the help
