89703 zip code
rcwade
89703 zip code not showing Repeaters. It doesn't register in the system. However I can zoom the map to find repeaters in my areas
blantonl
Founder and CEO
Staff member
Super Moderator
Dallas, TX
Can you walk me through the steps you are going through where you are having a problem?
rcwade
I click import on chirp and it gave me an error saying invalid zip code. This caused me to go to the main repeater lookup page on Radio Reference. When I put in my zip code nothing comes up. However I can click on Nevada and zoom into my areas and find the city etc. it’s like the zip code isn’t in the system.
Carson city is actually its own county.
AK9R
Staff member
Super Moderator
Central Indiana
If I go to the main database page and "Retrieve by US zipcode" using 89703, it takes me back to the main database page. That ZIP Code is one of a handful of codes used by Carson City NV. So, I tried the same thing using 89701 which is also Carson City. Same result...back to the main database page.
As a test, I used my own ZIP Code in Indiana and the system takes me to my county's database page.
Something seems amiss.
rcwade
I don’t think Carson city, which is a county is in the database
rcwade
The link you provided is the city not the county. Carson City should be listed as the city and county. Most imports are done by zip code crossed with county.
ltginrage
I just entered my IL zip along with some other local codes and it took me to the local county database page
rcwade
What I’m saying is if you zoom in the map it works. The search does not work for zip code.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
I’m pretty sure the RR database is missing that zip code and will need Lindsay to add it.
