Active A new active loop from Tecsun
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Interestingly this one is at least trying to make it usable by more portables by including more adapters. It also says it will work with radios without external antenna jacks, but doesn't say much about how....it doesn't cover the 90 or 120 mb, which may be an issue for some.
Mike
krokus
Southeastern Michigan
Interesting. I wonder if the TRS plug is compatible with my Sangean made radio's external jack? Secondary, I wonder how well the loop would work, directly plugged into a radio? (Basically, the natural bandpass of the loop, if not "blocked" by active electronics.)
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
I don't understand your second question. If you were to look at the venerable Sony AN-LP1 (which I am told you can still find on fleABay) that loop antenna plugged directly into some Sony radios directly, and worked well for what it was. How well this Tecson model will work we'll have to wait and see...Mike
krokus
Basically, is the loop just a loop and a selector switch, or does it have an amplifier inside that housing?
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Have no idea beyond what is in the article. Like I said, we have to wait and see...Mike
WA8ZTZ
S.E. MI
Seems like the only way it could work with radios lacking an external antenna jack is by some means of
inductive coupling... stay tuned.
WA8ZTZ
S.E. MI
My experience with all-band portables is that they usually have adequate sensitivity on the SW bands and any attempt to increase the signal there with an active preselector may result in overload if the gain is cranked too high. However, these portables could use some help on the AM broadcast band and especially the LW band. For example, with one of my portables, only a couple of local LW beacons can be heard without using any external antenna. Hook up about 50' of wire and couple it to the portable with a ferrite and 25-30 or so beacons can be heard daytime (more at night).
krokus
This antenna comes with a coupler, for that type of connection. That is in addition to the two modes of physical connection.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
it might be that odd-shaped box that's on top. It does have a frequency range selector on it. Again, gotta wait and see...Mike
mbott
EN80nd
It helped mu understand the AN-48x a bit better.
Mike
chipbutty
Probably similar to the Degen DE31 loop which is a very good performer. I have one. Radio Jay Allen compared it to the Sony ANLP1 and it favoured very well. I'll buy the AN-48x to see how it compares with the DE31.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
It's now available from Al-Anon and perhaps later this year, other distributors like Universal Radio...
Mike
mbott
EN80nd
Mike
Universal would be nice. Driveway to driveway, it's 13 minutes. Which also makes it not nice. :)
Mike
