All radios are designed to operate on specific frequency ranges and are designed or limited to different power levels. Your GMRS radio most likely is not designed to work well, or have the capability to be programed into the 2 meter ham band and most likely has a very limited power output. If you are studying to get your ham license and close to a metro area, you might want to invest in something like a Baofang UV-5R off of Amazon for under $25 to be able to monitor the Ham frequencies on ham repeaters in your area. Depending on terrain and your location, you can generally hear max 20 or so flat miles with it and when you get your license, talk about half that distance back with a clear signal with the limited 5w output power it has.
The free "repeater book" apps on android or iphone are the best sources for finding ham repeater frequencies in your area if you set it to access your location and the frequiencis to list. My "send people to go to study" is a free site, Hamstudy.ORG. Free for desktop computer use. I think they have to charge for registering for an app download to use on a cell phone. Gives you flash cards with a clicker to make sure you understand and learn why the correct answers are correct.
Old guy here, yep a VE to test both ARRL and W5YI if needed. I got my tech plus licence (5 levels of licenses back then, 3 now) to learn in 1979. But, Still learning and sharing what I can. Good luck to you Sir. PM me if I can help in any way.
If I can find 20Amps of 12 Volt power, I can talk to a select group of like minded people around the world. Look ma, no hands, or internet needed.
