A Note regarding submitting Frequency information
N7OLQ
Scanning since '77
Utah
A general message to anyone wanting to submit Frequency data for the 800MHz public safety band:
Please do not use the FCC database as the primary source for updates. You can use it to validate things, but the FCC data can not be trusted. The
FCC manages the Regional frequency issues in the 821 MHz public safety band a little different than the VHF/UHF bands. The FCC doesn't require accurate location information on the license as long as the change is approved by the regional frequency coordinator (currently Steve Procter). The FCC authorizes the regional committee (Region 41 here) to manage the frequencies in the pool without FCC intervention when it comes to what frequencies are used at whatever locations.
So the FCC data is only for "clues" as to what is happening, it will not be an accurate picture of what is currently implemented.
Thanks,
Brett - N7OLQ
B
boonez
Guest
Do you have the link to the FCC database for inforamation on the frequencies.
B
boonez
Guest
I have attempted to go tot he site and I clicked on the link, but it just gives me an error message when i try to search. Can you me me an example on how to search?
N7OLQ
Scanning since '77
Utah
1. Click the Licenses (orange button)
2. Use the pull down and select 'By Licensee Name'
3. type in: Utah Communications Agency
you should get a list of licenses
If it doesn't work, you might need to adjust your security settings or something.
B
boonez
Guest
I did as you staed and this is the error mesage I recieve:
Last Request was Canceled at Sat, Nov 20 at 15:43:52 EST on Server wireless2.fcc.gov:ula
Please try again.
License Search Home
