Benzman66
I have a Pro-96. Recently started doing a strange thing. On the frequency 462.950 which is a standard med frequency used in many areas for dispatch, my scanner is constantly sticking on it because of a "weak something".
Now, it isn't a transmit signal because all my other scanners are not picking it up. I am really not sure what it is. It seems like interference and no matter how much you turn the squelch down, it will not leave the channel unless you press scan. Then when it scans again and a call comes thru on that channel, it will stick again with a faint squelch sound afterwards. It received calls ok though on every other channel as well as this one too.
It seems more like static and sometimes you can hear a faint hum in the background when they do talk on the freq.. When you turn the ATT on, it eliminates the situation all together.and scans and receives normally.
I have been in the business for many years repairing electronics and this has me really stumped. I have thoroughly checked all settings (FM), etc,and no results.To save time and a lot of questions;
1. I do know about programming and the operations of scanners, so I am not a newbie..
2. There is no problem with the local transmitting system in Pittsburgh on this frequency, nor anywhere else nearby.
3. It is not happening with any other scanners of mine or my friends scanners.
4. No electrical interference.
5. No 'birdie'.
6. Antenna connector as well as solder post from antenna to board are perfect!
I also tried moving the freq to another bank but the problem still happens. Could it be a RF coil issue or chip problem? The scanner is a 1.5 CPU and has the latest downloads. Oh, by the way, I even re initialized it and redid the downloads thinking that may solve the issue, nope.
Thought I would bounce this off some of the techies on here. Maybe you can come up with something.
5. No 'birdie'.
