A Request To UniTrunker
Would you please add the ability to narrow the audio band pass so we can eliminate the offending wide very strong EDACS Provoice transmissions. This will help eliminate the distortion on multiple systems. Lowering gains helps but only to a degree. When traffic is heavy on both systems distortion is worse and setting gains is futile.
EDACS and Motorola share the same frequency ranges here. Both operate 851-860mhz. OKWIN uses 16 channels on Site 8 (Oklahoma City) EDACS uses 2 systems, Core Simulcast and Wide Area Simulcast Area. 32 channels. Both systems combined is 48 channels in just 9 mhz spread. That gets congested badly!
https://www.radioreference.com/apps/db/?sid=844
https://www.radioreference.com/apps/db/?sid=2810
The only way is to have a variable audio bandpass filter that allows to narrow or widen based on preference and multi system distortion. I experimented with HDSDR's audio bandpass adjustments narrowed down to 6khz total it worked. I know default is 12.5 but to wide for my area.
I prefer the OKWIN (Motoroloa) system because it sounds better than Provoice. Second reason is I can hear police from other cities on OKWIN :)
Third reason is you make awesome things happen in UniTrunker :)
Please pretty please :)
