Abbree AR-2520 Software?
mfn002
Bryan, Texas
Does anyone know where I can find the software for the Abbree AR-2520? I looked online and the Abbree website does not seem to have it.
transmission1
East Yorkshire, UK
Hi,
Just got one of the Abbree AR-2520 radios yesterday. Please could you let me know what the CPS software is called so I can try and track it down? Seems quite a nice radio with good audio. Have emailed the seller but no reply yet.
Many thanks
Simon
raymieboy55
I have found the same issue could you send me a copy of the software or a link to ware I can find it thanks
Hi,
Many thanks
Simon
Hi Simon could you send me a picture of the rj45 end of the programming cable so I can make up a wiring diagram for myself and post it for othe members thanks
sp3vss
Mic pinout:
1 Brown PTT
2 Red +8V input to 3V3 IC
3 Yellow GND digital
4 Green TX
5 Black GND audio
6 White Mic
7 Gray RX
8 Blue SPK
If you want to send, connect pin 1 to GND.
PTT2 button goes on the 5th leg of the integrated circuit
Hannes_Seppl
I use the AR-2520 V1
Plus the original cable
The cable is recognized by the PC and assigned to COM port 6.
When I select the COM port in the software and want to read or write, I always get the message "communication error".
I have also tried other converters. With these I have sacrificed a network cable and connected pin 3 to GND, pin 4 to TX+ and PIN 7 to TX-. I swapped pin 4 & pin 7.
But no matter what I try, it doesn't work.
There seems to be no handshake between the radio and the PC.
raymieboy55
What pc? Only ever worked on windows for me tried it on Linux and had the same problem , have a look on YouTube for Tech-Minds ABBREE ar2520 he tells you exactly how to do it and when to have the radio on or off plus there's a firmware update too
Hannes_Seppl
Thanks for the quick reply.
I am using a Windows PC.
It looks like my radio already has the latest firmware. But even an attempt to update the firmware like TechMinds failed.
How did you solve the problem? Was it solved by the fact that you are using a Windows PC?
Hannes_Seppl
It all looks so simple in the video from Tech-Minds.
I was under the impression that the device being switched on or off was only relevant when updating the firmware. But I will watch the programming video again and make sure I haven't overlooked any important steps.
raymieboy55
Yeah changing pc solved my issue, I used a butchered baofeng programming cable at first. also try updating drivers
Hannes_Seppl
I must have had a bad data cable.
I crimped an RJ45 plug onto a cheap Baofeng cable and it works!
raymieboy55
Excellent mate glad you got it sorted as it's a pain having to program repeaters in manually
vk3tk
Mine seems bricked after running the software and adding memory channels.
Is there a reset?
