ACARS Antenna
wyomingmedic
I would love to help, But I (and I bet a lot more folks) have no idea what ACARS is, what frequencies it covers, or where it is located.
A little help may be in order.
WM
killmoles
Des Moines, IA
ACARS = Aircraft Communications Addressing and Reporting System
Any antenna that receives approx 129 through 137 MHz will work. To answer your question in the Aircraft Monitoring Forum, I believe vertical polarization is better.
Choose an antenna for that band that fits well with your situation and you should be fine. A discone would be good, or something dedicated to the band like a J-pole, etc. would be too. I've never listened to it myself but I assume you want omnidirectional since planes are all over the place.
majoco
Stirrer
New Zealand
A J-Pole made for the correct centre frequency will be better than a Discone. A discone is just like an untuned vertical with a good ground mat - it radiates and receives equally badly in all directions! A J-Pole does have one disadvantage for aviation in that it does not receive very well from overhead - but fortunately aircraft do not remain exactly overhead for long. The was a good construction article in the Wiki on making a J-Pole from copper pipe with no insulators required- usually called a plumbers friend!
Cheers - Martin ZL2MC
