I think since I've had this Winradio I've tried every ACARS decoding package available....even stole a copy of Airnav 4 from a co-worker to try it out (wasn't satisfied with the way it kept NOT plotting obvious decoded location transmissions; POSFIX is free and does better, though the map-making might be intimidating for a beginning user).
I've settled on ACARSD because a) it's freeware/non-commercial, b) lets one participate in the worldwide ACARSD circle of users, c) still allows you to use WACARS and other packages to display/log its decodes, d) lets you set the decoder passes to a high number to take advantage of a seldom-used or high-end CPU to eliminate bad decodes, and e) has Windoze & Linux versions.
That does give me an idea, though...I'll have to try out the Pro-94 as a possible dedicated scanner for ACARS....might be that excuse I've been waiting for to pick up a Pro96.
