Will you be running a server?
Let me know what your server name/IP is.
I’m running the WNYacarsd server, check it out.
Start here:
http://www2.demis.nl/mapserver/mapper.asp
Define your map.
Save the map image as Card-1.gif, Card-2.gif, or Card-3gif in your acarsd directory.
DON’T close the page after you save the card-x.gif.
Now open your client/server.
Click MAP then DEFINE MAP SETTINGS.
The top three columns = card-1, card-2 & card-3, first four rows, are where you enter the map coordinates.
From the above site, coordinates will be in the lower left hand side of the status bar in that window.
Move your mouse to the top of the map window keep it on the map, enter that
latitude for the top position of card-x.
Now move the mouse to the bottom of the map window, keep it on the map,
latitude = bottom position of card-x.
Then move the mouse to the left of the map window, keep it on the map,
Longitude = left position of card-x.
And move the mouse to the right of the map window, keep it on the map,
Longitude = right position of card-x.
Click SAVE when you finish entering the map coordinates.
Let me know if you need more help.
