Robbyroy, like DanHenry said, I used 136.8 a lot. Not running acarsd anymore. I added an audio-out jack to my 2052, so i don't have to change the volume. If you have that ability on your scanner, do it, a lot better than trying to get the volume just right. Also, that radio was connected to an outside groundplane, which enhanced reception of course. If I can offer anymore suggestions, let me know.
Where is Richlands? I'm in the triad.
Also feel free to PM me if I can help.
Just downloaded it again, so I could review the settings. I was also running the linux version, but I assume most of the settings will be the same. Bump up the decoder passes if you are running on a pc with decent specs, had mine set at 10. Activate the "show only good msgs", download all the plugins and activate the ones you like, especially the one(s) that show you the airplane pix and details on the side. Extended mode on, resolve airports on. Set up a map and let it show you the locations of the aircraft. I ~may~ still have an NC map on another box if you need it, was running it on 3 boxes at one time. ( Side note, once you get comfortable with it, if you have a pc you're not using a lot, set it up as an acarsd server, and let it run all the time, then you other computers can talk to it to get their acarsd info. This also allows you to connect to your always-running acarsd server from anywhere in the world, pretty cool. ) Databases - make sure to update your databases before you start running.
All I can think of right now.
