I want to add a MUTE button or switch to a couple of external speakers. If I just install a basic On/Off switch in series with the speaker wire will it do any harm to the scanner's audio circuit to leave that line to the external speaker load open with no load? Or do I need a SPST switch that inserts a resistor load to the scanner while the normal speaker's 8 ohm load is removed?
