Adding Frequencies to the Database?
sefrischling
Public Information Officer
New London, CT
Is there a way to add frequencies to the BlueTail software?
The Waterford CT P25 800 system, that is used by Waterford and New London, as well as having some other towns on the system, does not appear in the system. Only the frequencies for the Millstone Nuclear Power Plant (Dominion Power) is in the database.
btt
Jew lover
Wa State
Currently, there is no way to add frequencies to the database. You can manually enter control channel frequencies in "CC FREQ" column.
sefrischling
New London, CT
The system has 7 CCs, no alternates. Is that possible to enter? If so, I'll play with it in the morning.
Thanks.
btt
Jew lover
Wa State
Yes, you can enter all of them on separate rows. Highlight them and then select <write to roaming flash>. After that, enable roaming on the P25RX Config tab. Make the timeout a high value like 9999. That way, once an active channel is found, it will stay on that channel until the signal is lost.
