Adding more frequencies to a call node?
Clay_Lowery
Nashville, GA
Could I get these two frequencies added to call node 4538? Also, is there any reason when I try to add a frequency that I own to a playlist, it says "ID can only be accessed by system broadcaster or an admin"?
153.980WNAB928BM186.2 PLBerrien Sch BusSchool BusesFMNSchools
150.845BMCSQAAAAAA Road Service (half-duplex, not repeated)FMNBusiness
If call node 4538 is yours you need to submit a new request to feed the frequencies listed (along with the original ones), once approved you will be notified and then can be added to your Node. Under Broadcastify TOS feeders can't just add frequencies to a Node without approval.
Clay_Lowery
Nashville, GA
I'm trying to get somone who will be on here because after this was sent to me, I haven't heard back, and I have already asked.
In order to add frequencies, which you were told can be done, you need to complete a new/updated application HERE. Once it is submitted and approved then you will be able to start broadcasting the new frequencies from your feed.
There is no one that specifically monitors and responds to the forums, as support requests are submitted and responses sent back to you online.
