Adding TGIDs
jperuta
Wethersfield CT
Good evening, is there a way to add TGIDS that arent in the radio reference import feature? I'm looking to add them directly into the PPS sofware, i dont see the option. I know that in proscan you can. Thanks in advance.
NOTE: This is for adding them for trunked systems, it is different for conventional frequencies.
You can add them in E2-1 by clicking in the block for TGID List for the currently programmed system you want to add it to, not on the TGID List title showed, but for the system you want to add it to.
They can also be added in tab C1 in the same place, for future use, it WILL NOT be added to currently programmed systems from this location.
